Trouble Changing email notification Sound (Win 10)
But what sound do you hear NOW when you get new mail via the web browser? THAT is the sound that needs to be changed in the sound control panel.
Also why not just stop bashing your head through a wall and install Thunderbird on the computer?
The sound I hear now is somewhat of a "chime"......I do not wish to install T-bird at this time......AND, I have tried multiple times to change that sound but, ALWAYS defaults back to the default "chime (sorta a "ding-dong" sound...
So, this snide comment you have given reflective of what this forum is about or represent??
I came here to learn, to understand and, I am not sorry for my difficulties in my knowledge of computers...
Doesn't help that most of the system sounds sound the same. You just need to change them one at a time and send yourself test emails until you find the one sound you need to change.
I'm sorry this is difficult, but you're making it difficult on yourself by not just using Thunderbird.
So I get what is going on:
You are using ProtonMail
You are not using Thunderbird... you mentioned it because you used it on Windows 7
You are using ProtonMail on FireFox.
As mentioned, the Sound Notification you posted is for E-Mail-specific applications. Since ProtonMail is using Notifications, then in the same Sound Notification box, you will need to change the Exclamation option. But as noted, it will change for any other system settings/applications that uses it.
I second that you may want to use Thunderbird or some other E-Mail program so you can change it without changing it for other applications
I hear the difference in the sounds, not an issue with me...
have attempted to change "email notification" and "exclamation" sounds and the results are the same.
It is what it is, I have CLEARLY stated TB is NOT an option..If you cannot handle my choice, then, so be it, and let it drop.
I think 'why' is the only thing missing, you make a lot of silly computer choices that cause 99.9% of your own problems.
Apparently not.....
The listing shows and indicates what e-mail sounds are used for e-mail notification and gives me the ability to change that to any of those listed or, mu own...
Are you implying, that I go through all of those listed and find that default sound, and change/substitute my own?
Yes. One at a time until you find it. Then reset them to default and change just the one that makes the sound you want.
Just back taking a peek at this again....
I hear sort of a chime I suppose...
"...THAT is the sound that needs to be changed in the sound control panel...."
There are so many sound in this damned thing that all sound almost all alike!...I pick a wav sound file, select it and hope that it will play when an e-mail comes in ---and it doesn't...
