Printer not consistently communicating with computer.
I have Windows 10 and ever since Microsoft had me reinstall it to try to resolve something else (and failed) I haven't been able to communicate with my printer (connected by cord) unless the printer is on prior to the computer. How can I fix this so computer can be on first and it still work?
My guess is that you let windows install its own driver for the printer which you shouldn't do. You need to download the software from the printer manufacturer and install it that way.
And if the printer is wireless, I highly recommend setting it up that way instead of using the usb cable. What printer do you have? I'll give you a link to download the correct software.
Why would wireless be better than physical connection? That seems like more room for errors. I didn't choose any drivers. It was a reinstall of OS without deleting any other apps or data. I use a Canon MG6620
Download and run this software to install the printer.
Before running it though, go into programs and features and uninstall all software related to that printer.
1. Remove usb cable from printer before running the install software. Only connect usb cable when it requests it.
Wireless is so much easier, no cable to deal with, easier to use if you have multiple devices to print from.
In the end, its your choice though. I haven't used a usb cable in probably over 10 years or more.
