3d Mark 03/05 Scores :)
Here is my 3DMark05 score its with the settings in my sig, I have scored higher but don't feel like messing around with it agian.
I tried 3DMark03 for the last time with all my OC's on high, and interestingly, I got over 1000 points more! From 15276 to:
:D
EDIT:
And from 7254 to:
my score in 05 was 11267.. but with 06 i just didnt reach the 6000 :(
i bet its my processor, because the CPU tests ran at a stunning 0fps.. -_-
Def. your processor. Suprising, though, even so, that you still got that low of a score
It's because those tests are multi-threaded, so even a Pentium D 805 would probably score higher in the CPU test.
Heres what my little mainstream 7300GS 256MB can do at stock settings.
Its really not a bad card for its cheap price.....
That actually didnt seem to be too bad. But then again, for about $50 more you can get the x850XT, which will easily outperform it :P
I almost bought a X850GTO instead of my 6800, which i actually should have. But i was shopping at best buy at the time, and this was the cheapest card......even cheaper then the 5200 which was $119!!! Is that crazy or what? Why would they sell an FX card for that much? Even the top end FX card isnt worth that.
