I'm looking at this card and all the reviews look fantastic. Is this card good enough to play BF2 at high settings? What are your thoughts on this card?
I have it. It does play BF2 on high quite well. Its a great card for $150.
It sorta depends on what you're doing as far as which performs best. On games which use alot of the new shader coding and such, the newer specs on the X1600 allow it to shine. But the X850's seem to pull alot of muscle as well, especially the 16 pipe ones (stock, or unlocked).
The x850xt is better then the x1600PRO. The call is up to you whether to save. It would show a noticable difference in games. I would however save a little more and get a 7800GT or a x1800XT.
Yea its a good deal, asuming your talking about a x850xt.Well I'm primarily looking to play BF2 at all high settings. The 1600 I have only has 12 pipelines and I was told the more piplines the better on any card. Like right now my card can play BF2 on ALMOST all high settings but it struggles. Would this be a better choice? They are on newegg for $119. Is this a good deal?
Yep it's the x850xt. I just can't find the clock speed on it though. I think it's like 520mhz. Is that any good? Does it even matter or is the pipelines the most important part of the equation?
i would save ur money and get the x1900 xt. it is a lot cheaper than the xtx but only about a 10 mhz difference in clock speed which you can easily get by overclocking.
The x1900xt is over $300. I'm not spending that on a computer that I use for school and sometimes use for gaming. The x850xt is $125 shipped. Why in the world would I spend that much on a card when I get another gig of ram AND the x850xt for $150 less than just the x1900xt by itself?
Yea, the x850xt is your best bet then. Its clocked at 520/540 btw.
520 mhz isnt great. the xt is 1.45 ghz and it has 48 pixel processors.
Dude, what GPU are you talking about, there is no GPU with a core speed of 1.45ghz.
I think he's saying that it's clock speed is at 1450mhz. But honest to god I have no idea...
Yea, there is no clock speed of any gpu at 1450mhz. Honestly, i dont either.
yes im talking about the MEMORY clock speed. my bad for not clarifying..Haha. I was just looking it up. The core clock on the x1900xt is 625mhz....the memory clock is at 1450mhz. Is that what he's talking about then? Who knows.
