Post A Pic Of Your Pc Here :)
Heres are pic's of my computer, nothing special, except for a case mod i did.
http://rigshowcase.com/album_folder.php?u_id=340DlpCU&f_id=642
Click on the images for larger view
how come you didn't mount the plexi on the inside? it would probably look cleaner, as long as the metal edges of the hole are painted.
some wire management wouldn't hurt either. but i guess that might be kinda hard with that psu, spitting the wires right out the bottom like that.
not trying to be an ass, just trying to point out a few tips.
I was going to mount the plexi inside the case but the case is so small that there wasnt room for it to fit, So i just mounted it on the outside. As far as wire management i agree! Are there any threads on here that would help with that? thanks!
My setup:
Everything (Viewsonic VX2025wm monitor, Insignia NS-B2111 6 1/2" bookshelf speakers)
Receiver powering the speakers (Pioneer VSX-516-K)
Close-up of the receiver
Close-up of the speakers
Headphones and headphone amp (Alessandro MS-1s and PA2V2)
Close-up of bowl pads on the MS-1s
Dirkpitt289 said:
Here's my mess. I'm surfing, watching a movie and rebuilding 2 laptops. Its just what I do...
Heh you ahve the same 2 monitors as my school (sorry random)
but having 2 monitors is awesome i'd like to watch a movie while doing somethin else
Thanks but i will have to do some changes like put the harddrive down where the fan is and re seat the cpu fan because after i run Prime95 for like 30 min to test the system my cpu temps get up to 51C dont know why.
nice rig.
your hd will fit nice in the bottom slot and you'll still be able to put it in backwards without worrying about the cables hitting the fan.
your mass of cables would look better pinned to the top of the case, and ran behind the hd cage.
you have the northbridge fan installed? you may get lower mobo temps without it, seeing as you don't have lc or a passive hs.
