3DMARK06 Scores Here
Are you really going to spend 350 on fx 60? when you can buy a better processor for the same price? And are you a male or female? I get your avatar confused with your gender.
:o wasn't that obvious so far? you're the first one to ask tough :)
anyhow, what CPU do you mean?
Its not the highest he has in this forum after i overclocked my cpu to 3.4 ghz its gonna smoke that amd.With 2.88 i got a cpu score of 2400.
That would be the day conroe beats my cpu. But go ahead overclock it to 3.0+ and you wont get more then my cpu score i promise you that.
actually a core 2 duo at 3ghz will perform quite like an fx processor at 3.75ghz... sorry.
its shown in benchmarks to be 25% better than athlon 64. 3ghz*1.25=3.75ghz
plus, they're overclockable to 3.4ghz on stock voltage, on air cooling.
so you wasted $900 on cooling huh? lol
buying a super amazing cooling system and overclocking a chip way past what its normal potentials are isn't that tough, its just long boring and expensive which is why nobody ever does it... not to mention the maintenance is ridiculous... even on water cooled rigs. i mean i havent touched the inside of my case for its cooling system in probably a couple of months and that was only because i was bored so i decided to sand the ihs down to a mirrored finish.
i mean really, great overclock and everything, but core 2 duo beats it.
with an e6600 and that cooler, i'd bet you could surpass 4ghz quite easily... and therefore 5ghz athlon 64 X2 standards...
i'd say it all comes down to the fact that the core 2 duo #1 has better architecture, and #2 is built upon a 65nm standard... the fx series is still being produced as 90nm which gives it a big overclocking disadvantage.
then again, 3dmark06 could be different than other cpu tests... in either case the core 2 duo is still a better proc, and he didn't spend $900 on cooling for it. lol
yup but zalman 9500 is a good cooler but when i was at 3.4 i had to go down it was at 60 and going a little over.But at 2.88 my idle temp is about 39 and load 50.PLus you chip is overclocked amost to the max and the life of it is poor.I didnt even have to raise anything then the fsb to reach 2.88 and if i would go a little with oc ram and vcore it would overclock smooth like butter.I would never pay 900 for phase.No use just get watercooling for 300 bucks from dangerden and that is top of the line.At least that is what i would do.And 1+3+3=7 can you run pcmark05 on your pc and let me see the cpu and memory score of your pc.You could check out mines in the desktop computer section.Also you can check out my pc in the General Computer Chat in the Post A Pic Of Your Pc Here :) its on the 160 page on the botton you have to click on the links:) And i dont know if you knew but i had an fx60 machine.For couple of days.I posted it in my sig.It was very fast but comparing to core 2 duo its nothing.A core 2 duo like mine and with my motherboard is able to reach 4 ghz with watercooling.
I heard enough I want to see if his core 2 duo will score more then my cpu in 3dmark 06. and Overclock your cpu to 3.4ghz it wont score more then mines. Come on 3dmark06 test shouldnt take that long.:cool:
i want to see screen shots of the score, and the frequency of the chips overclocked so we can verify what frequency they're at... because an fx-60 at 3.6ghz should score more around 2700 if you ask me... either way, i dont want to hear anymore arguing i want proof lol...
i want to see if anyone can hit 10k in 06 lol
http://www.slizone.com/content/slizone/clubsli.html
one guy scored 13203 lol
thats with an fx-60 at 2.8ghz and two 7900gtx's...
not sure how valid 13203 is though lol that confuses me
ight men you want to see my conroe beat your fx hold up man.I am doing it now.But do you pcmark05 scores too man.First i gotta download it it takes about 30 min then overclocking like 1 hour and i am done.Mabye less.
