Boot with the DOS disk. At the prompt type in SYS A: A: Do the floppy switcheroo thing as required. Then when you are back at the prompt put the original back in and type COPY A:*.* A: Do that for each disk.
First, diskcopy doesn't copy the hidden system files needed to make the floppy bootable.
Second, copying the floppies onto the harddrive won't work... You can get them on there through XP, but when you go to format, it will use the Windows XP format. The problem with that is when he goes to boot with the floppy and load any DOS command, he will get an "INCORRECT DOS VERSION" error message.
He can't boot with a DOS diskette, because then he won't have access to the harddrive. DOS is 16 bit. Windows XP is 32 bit NTFS. DOS is incapable of reading an NTFS HDD. If he goes to type "C:\" he will get the error message "NOT READY READING DRIVE C"
He must do the entire thing by floppy. Trust me, I know what I'm doing. You obviously don't. That is a nice cut and paste from Google, but you are just misleading him.
Try "diskcopy a: b:" or follow these instructions if you have the files copied into a folder on the hard drive.
At the prompt, if you have MS-DOS 6.2 / Windows 3.x / Windows 95 / Windows 98, type:FORMAT A:/SIf you have MS-DOS 5.0 type using double density 5.25" diskettes type:FORMAT A: /360 /SIf you have MS- DOS 3.11 through 4.0 using double density 5.25" diskettes, type:FORMAT A: /4 /S Once the diskette has been formatted and the system has been transferred, you should be returned to your original directory. In this directory, type:copy format*.* a: [PRESS ENTER]
copy fdisk*.* a: [PRESS ENTER]
copy mscdex*.* a: [PRESS ENTER]
copy sys*.* a: [PRESS ENTER]
copy edit*.* a: [PRESS ENTER]
copy qbasic*.* a: [PRESS ENTER] (Win 95/98 users skip this line)
copy debug*.* a: [PRESS ENTER]
copy himem*.* a: [PRESS ENTER]
copy emm386*.* a: [PRESS ENTER]If you are planning to use this diskette as a diskette to load games or you feel that you need mouse support, you will need to copy the mouse driver onto the boot diskette. The MS-DOS mouse driver is generally mouse.com / mouse.sys. Locate this file and copy it to your bootable diskette.
The following links list all dos commands for 6.22. http://www.computerhope.com/msdos.htm
http://www.uv.tietgen.dk/staff/mlha/PC/Soft/DOS/com/
Then apparently you have never heard of
NTFS4DOS 1.8 (read/write NTFS from DOS)
http://www.freewarefiles.com/program_9_90_11100.html
I used that back when I was dual OSing 98 with Linux on a second drive in the old case. Besides is ismee even running XP or a dos, .3.1, 9X, or ME system? Since 6.22 is 16bit to effectively recreate any of the floppies you need to be running a 16bit OS namely 95 or simply an older dos machine with 6.22 on it already. WIN98-ME Dos 7.0+
Maybe we can make it even more complicated for the poor guy. I'm not talking about any other O/S... I'm talking about DOS 6.22. Let's try and stick to the basics or before long you'll be having us talk about time travel.
