{LSK} Otacon
banned
Umm actually your wrong yet again. The reason i went from 2.9gb/s to 4.2 was becuz of my processor. My old P4 had about a max bandwidth of 3.2gb/s, but it would only go to that if i OCed it to 3.5ghz. Your harddrive has NOTHING to do with your ram bandwidth. Nothing. And yes, your hard drive does effect the speed at which windows loads, but so does your ram. As you just said, it loads it into your ram. Do you try to be stupid or does it come natural? Switching from PATA to SATA have nothing to do with your memory bandwidth. 2 completely different things. I can run my PATA by its self and still get 4.2gb/s. The only difference its the data rate of the info coming from the hdd, to the ram. Which my PATA was 34mb/s and my SATA is 62mb/s. Which actually my SATA seems to be running slow.
