3DMARK06 Scores Here
7304 on 3dMark06 :) i dont think its bad for the system i have.
:eek:
how come 2 7800gtx scored only in the 7k? you should be hitting the 10k+ like tommy did with 2 7900gtx! he has the same processor like yours. Is it really that much difference between 7800gtx and 7900gtx w/3dmark06?
I just recently voltmodded my 7900gt to 1.4v and 635/1800mhz. My score with my opteron 146 at 2.8ghz gets me (5339) in 3dmark06!
Yes, theres a huge difference. The 7800GTX is more similar to a 7900GT.
Here's my score, but then again its not half bad for a 3700+ and a single 7900gt, might be getting watercooling sooner and then my cpu will be above its current 2.75 in no time, and my gpu will be able to hit half decent speeds, may have to try the volt mod.
I get ~5000 in 3DMark06 @ 500/1600, just got this card a few days ago, so I'll try to voltmod it soon, memory goes stable up to 1800 MHz, while GPU definetly needs more juice, max stable at 525 MHz.
with my new x1900xtx :D
thats 1100 more than with my old 7800gtx woo!:D
wow... 2 7800GTX's outperform a x1900xtx? i wouldnt have guessed that.. :confused: :eek:
( i know 3dmark scores dont say much.. but i find this result rather odd tough )
Come on you know that score is for 7800gtx. Not x1900xtx
x1900xtx scores around 6.5k at clock speed and at 7.4k when OCed w/the processor score ofcourse!
so instead of wasting your money on 7800gtxs just buy 1 x1900xtx or x1950xtx that will out perform both 7800gtx. And with sli 7800gtx you still cant use HDR and AA+ AF at the same time!!
With my newly built computer i get ~5000...not to bad for a budget computer with room to expand on. im hoping to get a new graphics card for xmas...maybe a 7900gt so later on i can get another n sli them.
With only one of the 7600gs running(turned sli off)...i only get about 2700...when i have sli enabled i get 5000ish...off a little by a few points (reformatted my hdd and lost my scores, will run again and edit with exact score but it was 49** last time i ran it). Cant wait to try to OC my rig and see how that changes things
My laptop gets like 1300 or so, so this is a big improvement. I only wish that i bought my laptop from a place i wanted to and not just gone to best buy with my parents...they pitched in and i had to buy it from a store they could go and complain if something went wrong...uhhh...the 300 bucks they gave me didnt help me much cuz the $1700 laptop i bought i could have gotten much better for like 1200 now that the core duo prices have dropped since they first came out. i wish i had something a little better than a 7400 go gpu in it but hey it runs oblivion at high settings well enough to play it...but the new computer wipes the floor with that one (which is what i said when i got the laptop relevant to the emachines i had before lol)
amazing the money we spend on new technology that quickly get replaced by something better and you realize that what you just bought is worth like half of what you just paid for it...damn economics....damn technology (ahh but i do love it lol)
idk...decent score for a $700-800 computer i guess...prob less than that after rebates (although i did use my old hard drive with its copy of windows on it to save money...200 for windows plus hard drive...so i saved quite a bit from that)
Hehe prepare for a serious boost there.
yes, you'll be like 3 times as powerful without overclock. lol
thats a lot.
edit: hmm maybe a bit less... but, it is an x1900xt i thought u said xtx. my mistake. my 7900gtx paired with my athlon 64 X2 hit around 6166 or something like that.
of course, that card's gone. my 7800gt will do just fine until i upgrade it after DX-10 cards are designed and on newegg lol
That was on my AMD 64 3200 @ 2.4 and my 6800GT @ 395 Core 1100 mem. My new rig in the sig gets 5877 stock. Overclocks coming soon. :D
thats a low score for you videocard but then again its xt not xtx. Lets see if your rig can score 6877 with oc'ed which 1000+ increase. btw what was your cpu and video score?
Thats not too low, it's actually pretty decent.
The only difference between the XT and XTX is about 25Mhz core speed, and 50Mhz memory speed (I believe).
What did you get for a cpu score?
CPU Score
Like 2100 something I think. I'll have to post it on ORB and/or run it again. :cool:
