jp198780
what do u mean pretend 2 do work? does it actually do something? and what does it do?
didnt answer my question
didnt answer my question![]()
Its not a process so it doesnt do anything!
Show me one that has, not just where it says it will!!!This was found needed in the early versions of Windows where cpus would burn out if they weren't given some small task to keep them occupied.
Leave your system running in the bios all day and your cpu will cook! There's nothing there to task the cpu. Essentially it start running full steam ahead looking for some task to perform.
lets all leave our rigs at the bios setup screen until after christmassanta will buy new ones
Got one that has been for 35 minutes, started at 27C now its at 32C, Lets see what it will do!!
Well its almost been a hour and its staying between 32C and 33C, must have a special CPU! Hum
The newer boards now have cpu overheat protect type circuits that would most likely throttle down the cpu's voltage or shut the system off before you would see what would have been the case on old boards. You would have to go back a good number of years to see where and why the system idle process was developed.
Why dont we just contact Bill Gates? He's only $95 an hour on phone, and thats on sale...Or someone could just E-mail Microsoft and ask....maybe...or maybe Santa diliver the answer as a present., heck I duno. Anyones guess is as good as mine...well, some aree better, but if no ones right, then we can't critisize each other if we have no positive answers ourselves...well we can but its hipacritical...sorta...heck, someone google it er somethin...
my question is answered, can u let this thread die?
damnn...
Die Die![]()
