Official Screenshot Thread
[-0MEGA-];545680 said:
It's so obvious you have pixel doubling turned on.
No it's not obvious anything was turned on. As explained earlier the method of capture was not ingame but use of a shareware screen capture program. For some reason the F keys on MS Internet keyboard(programable) are unavailable while in some games. When starting the system the F8 menus are readily available. That suggests the game doesn't respond when the F8 key is pressed. Thas has been the case in the expansion pack with that and the prtscrn key as well. Here are some PREY screens to look over in comparison with the assigned hot key ingame.
nice screens...prey right? i like the screenshot with the hand..awesome
Everybody was "dazed and confused" when I posted some screens from FEAR without the pixel double option enabled nor the force dx8 shaders. But the voice of reason dictates posting some Prey shots to show that the texture not pixel settings are the ones raised. I've run some extensive searches but still haven't found an alternate screen capture program to get some good shots from Fear and the expansion pack addon. :( Here's a few others from Prey you can look over.
Well you gotta admit, it looks a lot similar to the picture I posted with pixel doubling on. You can't exactly blame us for guessing that was the problem
The model card doesn't really offer support for having that on. I was able to get the antistropics in Prey going without a hitch there with the various levels of bilinear, trilinear, 2x, 4x, 8,x, and 16x. I used the trilinear without hangs in the game itself so far.
And if you think those are hard to get try these guys on for size. :eek: !
That was close! phew...
I managed to get a few shots from FEAR while trying out different freewares that turned out to be shareware programs. But that was only shots from the initial opening of the game. None of them would capture any of the "good" and best ones you would want to see. Here's a few of the "???" no activity opening.
Then there's the occasional shooting a lock off of a door.
And then your guide suddenly dissolves in front of you for some unknown reason! :eek:
This guy didn't look so good after seeing that one.
Now to find some freeware program that capture further into the game plus some from the expansion pack?
man you need to enable AA just that too pixelated for me
when i get FEAR from best buy ill take some shots.
Somehow my OC'd (550/808) 7900GT can handle FEAR on full settings even tho there isnt a 1280 X 1024 for some reason
The resolution was 1280x968 as the game's highest setting. Here it still looked like 1280x1024. When you do run the game you will see how the view gets distorted when seemingly telepathic harrassment by an enemy you are after is heard.
It's not the lack of AA, the screen shot is taking every 2nd pixel (best case) from the scene making it look blocky.
The ingame captures are generally the best unless you need to convert from tga, png, or bmp on some into jpg for posting. I've just about given up on finding a capture program that will get some screens in better shape then that one did which was only able to grab the 11 total. The lack of an ingame option to assign a hot key makes matters worse! :mad: ruff it is! I got better screens from State of Emergency converted from bmp to jpg then those!
