Overclocking QX6700
eh
i have it unlinked atm at 1066 and memory 2.1v
Memory Info:
Type : DDR2
Channels # Dual
  • Frequency 533.3 MHz
  • FSB: DRAM 1:2
  • CAS# Latency 5.0 clocks
  • RAS# to CAS# Delay 7 clocks
  • RAS# Precharge 7 clocks
  • Cycle Time ( Tras) 24 clocks
  • Bank Cycle Time (Trc)
  • Command Rate 2T
those clocks are disgusting!!!
change them asap to 5-5-5-15 at least or better yet whatever it says on the box
ok great, how do i change the clocks.
and how do i keep the overclock on the video cards permenent? do i have to overclock the video cards everytime i log into windows?
lol
ok i went to FSB and Memory config
went to Memory Timing and i seen the clocks.. shoudl i change them in order
up to down 5-5-5-15 ? and how about the last one. gives me an option auto, 1 clock 2 clocks.
there is fwe things at the bottom too, but no clue what it is.
As I told you online, those are very high timings, lol.
I would make sure the voltage is at 2.15v, and then set them to 5-5-5-19-26 for starters, and set it to 2 clock (2T).
(btw, im doing some homework now so I cant get on msn :))
okok.. where u get that extra 26 from?
Parameters
tCL ( CAS Laterncy ) 5
tRCD 7
tRP 7
tRAS 24
Command Per Clock (CMD) 2T ( auto )
***Advanced Memory Setting***
tRRD 4
tRC 30
tWR 6
tWTR 10
tREF 7.Su5
now tell me these adjustments below r right
Parameters
tRCD 5
tRP 5
tRAS 19
tRRD 4
tRC 24
tWR 6
tWTR 10
tREF 7.Su5
ok here is my CPU-Z memory info now
Type: DDR2
Channels # Dual
Frequency 533.3 MHz
FSB: DRAM 1:2
CAS# Latency 5
RAS# to CAS# Delay 5
RAS# Precharge 5
Cycle Time (tras) 15
Bank Cycle Time (trc) 30
Command Rate 2T
Type: DDR2
Channels # Dual
Frequency 533.3 MHz
FSB: DRAM 1:2
CAS# Latency 5
RAS# Precharge 5
Command Rate 2T
I got the 26 from the Bank Cycle Time, which is under the advanced. But you dont need to do that if you dont want to.
Thats very good that you got it lowered, now if you feel brave enough, try lowering it to 5-4-4-13. I wouldnt try to go too much lower, since it may not be stable.
ok now mine reads
5-4-4-13 and 25 cycle time my windows opened up just fine too
good good?
Much better. If you ran PCMark before and after, there would be a fairly significant difference as well. You will also probably notice a slight difference in gaming performance. (nothing too much, maybe 1-5fps).
Score total : 1091
here is a detailed score
HDD - XP Startup 12.35 MB/s
Physics and 3D 297.65 FPS
Transparent Windows 699.75 Windows/s
3D - Pixel Shader 558.63 FPS
Web Page Rendering 4.47 Pages/s
File Decryption 96.52 MB/s
Graphics Memory - 64 Lines 3779.7 FPS
HDD - General Usage 9.42 MB/s
Multithreaded Test 1 / Audio Compression 4340.26 KB/s
Multithreaded Test 1 / Video Encoding 608.26 KB/s
Multithreaded Test 2 / Text Edit 225.52 Pages/s
Multithreaded Test 2 / Image Decompression 49.65 MPixels/s
Multithreaded Test 3 / File Compression 15.4 MB/s
Multithreaded Test 3 / File Encryption 90.51 MB/s
Multithreaded Test 3 / HDD - Virus Scan 81.02 MB/s
Multithreaded Test 3 / Memory Latency - Random 16 MB 14.57 MAccesses/s
