INTELCRAZY
banned
How many would buy it if it demands so much?
			The designers mention a 7800gtx playing it on med-high and a x1900xt playing it perfectly fine all high.. problem is i've seen omega's posts saying the 8800's would have a problem playing it. regardless i wouldnt play it on my current system.
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6200 or ATI X1300 - Shader Model 2.0
RAM: 768MB on Windows XP or 1GB on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7600 or ATI X1600 Pro (SM 3.0) or DX10 equivalent
RAM: 1.5GB+
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Same here....i will definatly get it when i get a new pcI would buy it if my computer could run it.
anyway, will i *buy* it? no
will i obtain it from methods that cannot be discussed on this forum? yes
I as well as others have seen reviews of Crysis saying that the game cripples dual 8800GTX's when on highest settings.The designers mention a 7800gtx playing it on med-high and a x1900xt playing it perfectly fine all high.. problem is i've seen omega's posts saying the 8800's would have a problem playing it. regardless i wouldnt play it on my current system.
The 8800 series are much better then the x1900XTX.The dx10 cards that are out are not all that impressive, it wouldn't surprise me at all that my x1900xtx could play it on high settings..
I think my new computer will be able to run Crysis, What do you think?
wheres the no as it would bore the living crap out of me option?
