raoul_1101
What are all these diferent versions of vista? what are the differences in software?
What are the differences between these two then? Why does one cost $120 and one cost $160? (other than differences in vendor)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2765086&sku=M17-2506
Drivers are all the same for Vista, they dont have ones just for Ultimate. The only difference between Ultimate and other versions is the amount of RAM it can support (compared to the x64 Home versions), and the software thats included.So, Vista Ultimate comes with better drivers and better driver support?
Whats the difference between Windows Vista Ultimate and Windows Vista Ultimate Upgrade?
Why would someone buy Vista from microsoft for $250-$300 when they can get OEM versions for $199? When you buy directly from Microsoft do you get anything extra that you dont get just buying the OEM's?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2765090&Sku=M17-2514
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2864286&Sku=M17-7418
with one Gb of ram vista ultimate wrok fine , but i got 2 gbs now soo its really working fast , just be sur to have 1 gb or higher if ur going ot get vista ultimate, and im sure most of the software and hardware ur going ot build ur new comp with will have patches and drivers out there for you
