butter
I know what I put together is a little over budget but you get soo much more than the kit
overbudget is fine, as long as i get the right thing set up here..
check out this image here
i guess the fillport thing is the fill tube on this image..
any good?
That is one way to run the system.
lol, didn't you say something to me about control and kit being more expensive? jus messing with you
any good?
can u think of any others? like better ones? i mean, like let's say with the fill tube in between rad and pump, or any improvements..
i'm just speculating..
blah blah blah
you get a lot more with the one I suggested, he doesn't need to buy all of it at once
hey that is what I said
there really isn't any improvement that can be made
hey, i did the math here..
Pump89.95Radiator59.95CPU Waterblock55.95Chipset Water Block29.95VGA Water Block63.95Fillport13.99Hose Clamp (for pump)1.89+11.89Thread Barb (for rad)2.49+12.49total322.5
add another 50 bux and get a whole H20-220-APEX-ULTRA-PLUS system from the manufacturer. with a manual, extra tubes, installing tools, infamous MC8800 (does anyone know if they even work, anyways? lol), and a bottle of cooling liquid. furthermore, with warranty and support.
yeah but that is only a 2 fan rad, the one i suggested is a 3 fan rad
Maybe something like this.
Don't be afraid to use your imagination.
Honestly I would have cpu and gpu on split lines with the chipset after the cpu.
Also, read this beginner's guide to water cooling
I disagree but whatever it's not going to be my system.
i think that's the perfect system here. cuz the CPU actually produces the most of the heat, right? so now i need a couple of those fork-shaped splitters too..
keep enhancing guys.. brainstorm!!
theresthatguy, man y do u disagree? do you think that a whole manufacturer-packed kit would be better? like one of these H20-220-APEX ULTRA + ?
I can't force butter to do anything he doesn't want, I'm just making suggestions
for your viewing pleasure, a tri-loop system
Well the 2 biggest heat producers are obviously the cpu and gpu which is why I would want them both getting freshly cooled fluid as opposed to the gpu getting fluid heated up however much by the cpu. Again preference.
I just meant that I disagree that the setup couldn't be improved from cpu->gpu-chipset setup.
jesus man, is it a SLI sys? what is that?? GGGGGGGGGOd!! MORE DETAIL PLZ1!!!!
SYSTEM SPECS
