Post A Pic Of Your Pc Here :)
Yeah.
Its amazing.
I haven't moved my TV back yet. Lol.
I've been playing Halo 2, watching TV, and on the internet. By switching inputs.
It will be awesome at the LAN.
CSS on this TV is amazing.
I was thinking of getting a p180 but then figured my fan controller would not fit with the door, how did you manage to make yours fit?
lol
I put it in the 3.5 inch drive bay? :D
you have about 3/8 to 1/2 an inch for the buttons to stock out, it's not flat up against the case
it is also nice if you wanna go to sleep to have the lights dissappear :cool:
lol
See? Newegg doesnt tell you important stuff like the clearance you have with the door shut. :P
Thanks though, mine sticks out at exactly 1/2 an inch, so I dont know how well that would work out.
It might. Definitely if you shove it in the case a little bit, not very noticeable.
lol
Same problem with my case :P
But i bought a lcd 5.25" fan controller and a 3.5" card reader so i wouldn't have any problems lol
Ok, i had WAY to much fun with the camera :rolleyes::D
Cathodes OFF
Controller panel OFF
Side fan/cathodes OFF
All OFF
The other switch turns off the front intake, you just won't be able to see it.
And i switched to the new panel without the LCD, just an easy swap. Can't decide if i like it. So what do you all think?
Cathodes OFF
All OFF
You have an X800 on an SLI board?
Yeah, im broke :D. Im saving for a 8800, shouldn't be too much longer.
I had this card on my HP before i built this one.
