How clean is your interior?
Kornowski
Oh yeah, I could put one there, but I don't think it'd make much of a difference really... There isn't really any holes on the front of my case there to suck in cool air, and I'd have to take the other side of the case off, which I can't do for some reason :p
Plus, all my cables are stashed there, so it'd be blocked :p
Thanks :D I know, lol, It comes in so handy, cable ties have become my new best friend :p
I was trying to make a light joke
How comes you dont have one at the bottom of the front of the case
I know, I wasn't being snappy, if it came across that way, sorry dude :)
Explination above :p ^
Michael
Any comments? :)
makmillion, where did you get those IDE cables from, I want them! Those exact ones, now! You got a link, in the UK? How much for shipping? :p
The cable is a Link Depot UV-ATA36-GN-3.
Manufacturer's Website
Oh, hes talking about the place ath the bottom right were you can put one..
Looks good, if anyone says theres not atleast a piece of tape in their computer.. its a lie lol.
I have no tape in my case, none.. at least none that I know of :D
PS: I'm not lying.
Kilauea
banned
Nothing too fancy about this desktop
Kornowski
I've got about 4, all holding the wires of my case fans to the side so you can't see them when you look in! :D
taylormsj
I have some tape holding one cathode and also some tape on my northbridge heatsink to stop electricity conducting between it and a capactior on my graphics card :)
Bradan
took me like 2 hours to do it all. worth it tho :)
still have to put the cathodes back in and loom some of that ugly wire at the back.
taylormsj
Looks GREAT ! im gonna revise my system tomorow too, recognize anything better about cutting the metal from the back plate of the 120mm fan?
Bradan
looks kinda kool... :p
my temps dropped 1-2 degrees, but my harddrive went up 2 degrees. bc its backwards and doesnt have as much air on it.
Kornowski
What about a few UV lights? You can get cheap ones, but figure on replacing them every year . I have 4 in mine, but only 2 work, the ones that I bought a few months ago.
I'm going to get some green 12" cathodes :D
So what did you do Brandon, cut holes in the MB tray, or simply run them behind it?
Rekon I could do it with mine? The only probleem is, I can't seem to be able to remove the other side pannel, could it be rivited in? Think I should try running them behing my tray? (see pics)
taylormsj
Looks realy good.
Here is my last attempt at moving cables around. Your thoughts??
Going from this
To this
Some cables behind
Working around the top fan is annoying, i want as much cool air to get to the ram slots as possible.
Your thoughts?
Bradan your case looks so nice now, im envious
