on newegg they are the exact same price, which is better? probably the 5000 i think, and this would allow me to upgrade to the phenoms later, if they are as good as they are cracked up to be![]()
But if you got the 4500 that would allow you to upgrade to Penryn. Which will be better than phenoms.
Not the Penryn... Penryn is mobile and the replacement of Merom. Maybe WolfDale or Yorkfield... And the E4500 is gonna OC better, E4500 +1.
Yeah, your right.
Doesn't the 5000 black edition have unlocked multiplier? So wouldn't it overclock better?
Yeah, your right.
i have heard of some getting higher then 3.4GHZ on a 4300 with air cooling
