Post your SuperPi Score!
Status
Not open for further replies.
Man, I'm struggling to get my E4500 above 3.5. It just doesn't like me. Hmm. Only 50Mhz would most likely bump me into 6th....
Same here, I got up to 3.4 from 3.29 and my score didn't improve, I'm guessing because when it was at 3.29 it had a higher FSB since I was running it at a 7x multiplier instead of the stock 8x.
Yep. A fresh windows install will always help. Maybe just have an extra small hard drive with a fresh windows install to keep around for benching...:P.
That's funny that it didn't improve. I wouldn't have thought FSB has that much impact on this. Try running it a few times, maybe some process was stealing a lot of resources or something.
Somebody explain why my stock E6300 was so high please?
Higher than an OC'ed one?
Either the non-stock was running lots of other programs, or the Windows installation is really messed up, or (most likely) it was a typo or he ran 2M or something.
My 1st test :) P4 @ 3.5 Ghz ~ 48sec
Heh. Booted at 3.57, though still not stable. My cooler isn't getting very hot, so's I think I'll lap my (warranty far gone anyway) processor before I try any more voltage.
What is your memory at? I noticed that I couldn't get to 3.6GHz because the voltage on the memory wasn't high enough.
Anyways, here's my new score. I'm in second place now.
Ech. My OCZ Gold DDR2-800 likes high voltages, but I can only give it 2.1 (the warranty is up to 2.2V +5%, or a little over 2.3V). I have a hard time reaching even DDR2-900.
i hate you :P
If the q6600 price drops, i might grab a DS3R or L and a q6600 :o
:D
I love the Q6600, it has to be one of the best overclocker-friendly CPU's, after all the QX6850 for instance doesn't usually get above 4GHz, so the Q6600 gets a higher overclock percentage for it's stock speed.
Nice score. Use the Super PI 1.5mod for more accurate scores though. I got my Q6600 up to 3.8GHz and it scored 13.xxx seconds, but it wasn't very stable so I didn't post it here.
I tried it but for some reason it crashed under Vista. Although I can run the original SuperPi, Orthos, 3DMark06, and I just finished gaming for over an hour straight. So who knows...
Status
