The market leading motherboard manufacturer Asus announces the first high performance boards to encompass the new Nvidia nForce 7 series chipset. The Striker II Formula hits the ground running with the top-of-the-range, blisteringly fast nForce 780i chipset, supporting all current generation Intel processors and the forthcoming 45nm "penryn" cores. If that wasn't enough this board supports three-way SLi, which means that you can run three identical Nvidia graphics cards in full PCI-Express x16 glory. The Striker II Formula is a feature packed monster.
- LGA775 socket for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron Processors
- Support Intel® next generation 45nm Multi-Core CPU
- NVIDIA nForce® 780i SLI™
- 1600(O.C.) / 1333 / 1066 / 800 / 533 MHz Dual channel memory architecture
- 2 x PCIe2.0 x16 slot, support NVIDIA® SLI™ technology, at full x16, x16 speed(blue)
- Support NVIDIA 3-way SLI graphics cards (triple at x16 mode)
- 1 x PCIe x 16 slot, at x16 speed(middle)
- 2 x PCIe x1
- 2 x PCI 2.2
- 6 x Serial ATA 3.0Gb/s with NVIDIA MediaShield™ RAID supports RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
- Dual Gigabit LAN, both featuring AI NET2 Support Teaming Technology
- SupremeFX II Audio Card with ADI 1988B 8-channel High Definition Audio CODEC
- Noise Filter
- Coaxial, Optical S/PDIF out at back I/O
- 2 x 1394a ports(1 port at back I/O, 1 port onboard)
- 10 USB 2.0 ports(4 ports at mid-board, 6 ports at back panel)
- Extreme Tweaker
- 2-Phase DDR2
- ROG BIOS Screen
- Loadline Calibration
- CPU Level Up
- ASUS EPU (Energy Processing Unit)
- AI Gear 3™
- AI Overclocking (intelligent CPU frequency tuner)
- ASUS AI Booster Utility
- O.C Profile
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
- LCD Poster
- Onboard Switches: Power / Reset / Cls CMOS (at rear)
- ASUS Q-Connector
- ASUS Q-Fan 2
- ASUS EZ Flash 2
- ASUS CrashFree BIOS 2
- ASUS MyLogo3
