Nvidia GeForce 8800GT / Rosewill500w psu
lol sorry about that. also sorry it took so long to explain it all, but from what i could see its gonna work just fine. even though it might get tight.
ya everything looks good
the u wanna get really depends on what kind of stuff u want to do
and the 8800gt will run it really good nice card choice
It will work fine, slow down and breathe.Only thing that would stop it would be the size. You better have some room in there for the Video Card.
Please check your current PSU if it's ATX. If it is an ATX model then that 500W PSU should fit perfectly into your case.
Is the XFXGeforce8800GT 512mb good enough to run crysis?
Like.. really good. Alittle bit passed medium maybe?
My 8800GT can play it on High with a resolution of 1680*1050 @ 25-35 FPS.
So yes as long as the rest of your system can keep up.
Does this look like it can?
AMD Athlon 64 4200+ x2 2.2 (4.4ghz)
XFX 8800GT 512mb
2048mb RAM
XCLIO GOODPOWER 500W ATX Power Supply
It's ok I guess for Crysis.
But I'll give you a warning, Crysis demands everything high end. Not just the VGA, but the CPU as well because of it's stupid ultra crazy physics.
Would there be any overheating issues? or anything to that sort? I just checked my BIOs and my computer is only running at 40C* will the card and the new psu uberly boost that?
