WIndows 10 DRAM Speed not shown properly.
That's pretty standard when you make changes to the BIOS. Especially if it's memory related as it's likely retraining the memory. Is it doing that on every startup now?
Only after I changed the setting. Not in subsequent startup.
I messed around with this issue a bit.
It seems that the original XMP is not necessarily for the higher speed DRAM. In order to run at the max speed of the ram, I need to change the XMP.
I downloaded the Ryzen RAM calculator that suggest the new setting. Here's the suggested setting to make it run faster. Can someone advise if I should do it?
The profile you have selected is for Samsung B-die, which your memory is not based upon, so those likely won't boot at those settings.
You might be able to load XMP but then decrease the frequency to 3000 or something, I had to do that with my b-die kit on the 1700 Ryzen.
This is the picture of my computer, without modification. I should be concerned with the top 5 numbers, right? The numbers seems to match on the Dram calculator.
This is the spec of my computer. Can you help me what to select on the following in the Ryzen Dram Calculator:
Processor
Memory type
Profile version
Memory rank
Frequency
Motherboard
PS: My research seems to say the CPU is a Zen + AM4; and the Memory is a Samsung B Die.
AMD Ryzen 7 2700X Processor
ASRock MicroATX Motherboard (B450M PRO4)
Corsair LPX 64GB (4x16GB) 3200MHz C16 DDR4 DRAM Memory Kit
Seagate BarraCuda 2TB Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM
HP EX920 1 TB M.2-2280 NVME Solid State Drive
COUGAR MX330 Mid-Tower Case
ZOTAC GeForce GTX 1060 DirectX 12 ZT-P10620A-10M 6GB 192-Bit GDDR5X PCI Express 3.0 HDCP Ready Video Card
EVGA - 600W ATX 12V/EPS 12V 80 Plus Power Supply - Black
This has been a very frustrating experience trying to correct the ram speed with my PC.
I did everything I learned by watch a few youTube tutorials and changed to the xmp profile, then change the various number like the TCL, tRCDRD, etc. And yet task manager still shows that I am running at 2133.
As a last resort, I have sent ASRock support an email and hope that they have some solution to the issue.
Worked with ASRock support and didn't get the issue resolved.
It seems the problem is the MBO (as someone had suggested). I am trying to get an RMA to return the MBO for a new one.
If I am going to have a new board, do I have to reinstall Windows? Would the keycode work with the same model of MBO?
If its the exact same motherboard, you'll have no issues whatsoever. In fact, as long as its the same series as the original you should be ok. The chipset is what matters most.
I guess the last thing I want is to disassemble what I had built. I made up a list including of marking each cable's position to the numbers in the diagram and taking tons of pictures before I take it apart.
There are plenty of advises on how to assemble a PC. Any suggestion on disassembling?
The only cables that can be a hassle are the front panel connectors but if you build enough pc's then its pretty simple.
I had only one.
I'm going use some stickers labeling the cables referencing the MBO diagram. And I am going to take a lot of pictures first.
When I reattach the CPU, I'll need some thermal paste, right? How do you clean the old stuff?
Yes, you'll need to apply new thermal paste, I use arctic silver 5. I use a paper towel to remove most of it then use rubbing alcohol on the paper towel to remove the reset.
