That PSU would be a good choice for any of those cards.
I still think the issue is down to your PSU, so get that PSU and try it.
all of your diagnostics are about PSU, are you a PSU retailer or something?
The purpose of disconnecting the SSD and HDD, prior to clearing the Bios, then booting to see if you can get video to get into the Bios, is to remove Windopes from the equation.
i.e. If he then can get video to boot into the bios, then it may be a Windopes issue, if not then it must be a hardware issue. One other thing I would point out, is that when I first built this machine that I am on, it would boot into a "BLACK SCREEN" because of "DEFECTIVE RAM"; i.e. "Buffalo Select" RAM that would not support it's default timings; though it would work OK if you slowed the timings down. Changing the RAM solved the problem.
EXPERTS -- my foot !!
To Quote Denther : Windows isn't even initialized until after the BIOS Posts and finished it's splash screen. If you can't even get a video signal from the BIOS then Windows has nothing to do with it.
Ever heard of Boot Track settings ?
http://windows.microsoft.com/en-AU/windows-vista/BIOS-frequently-asked-questionsBIOS is part of the hardware of your computer and is separate from Windows.
I am quite aware that the BIOS is separate from Windopes. That is why I said that if he disconnects his SSD and HDD then clears the bios, (which would remove any Windopes altered settings from the bios) then tried to boot into the bios, IF HE GOT VIDEO BOOTING INTO THE BIOS THEN IT MIGHT BE A WINDOPES ISSUE. IF HE DID NOT GET VIDEO BOOTING INTO THE BIOS THEN IT MUST BE A HARDWARE ISSUE.
Can't you understand English ?
Re Boot track settings by Windopes, they do exist. BUT that is one of the things that MoronSh_t keeps secret because they use at least one of them in order to prevent illegal usage of Windopes.
I am very surprized by the following post by johnb35. It might possibly be true of his mobo, but it sure isn't true of most mobos.
Fine, I am leaving this thread per request. BUT first I am going to point out that these "EXPERTS" have all been recommending a new power supply. Whereas the first thing I would change is the Mobo battery, because a lot of Mobos require a good battery to turn on the monitor, and if yours is dying, you won't get video. Second I would point out that one failed boot followed by one good boot is indicative of a MEMORY CONFLICT. Third I would point out that defective RAM which will not support its timing settings will also give boots into a black screen. Fourth I would point out that Windopes does alter certain Bios settings pertaining to Memory Assignments and IRQ Assignments. Finally I would point out that Windopes puts at least one setting on the Boot Track of your storage device, (NOT IN THE BIOS - Per Stranglehold), to prevent illegal usage; and it may put other settings there for other purposes.
So have fun, buy a new powersupply, then maybe a new Mobo at the instructions of these EXPERTS. Ha Ha Ha!!
