750W should be OK for two 7970s, might want to go for 800W or 850W just to be on the safe side though.
I'd just get one 7970 for now and save your money. It's plenty powerful enough. Get the higher wattage PSU anyway just in case you decide in the future you want to get another one.
From my personal experience the Coolermaster 212 Evo is much more quiet than the stock Intel coolers. The fan is really silent even at 12v.
I've tested this against socket AM2+, AM3, 775, 1155 and 2011 stock coolers.
It's also much much better at handling overclocks.
Yes, the CX 750 is a good unit. It's a brand new addition to the CX-series, so it's more efficient and such.
Also, you can run 2x GTX 680 on a 700W with a high end 1366 CPU, so a 750W can easily run 2x 7970s.
It's a good unit, but you may want to throw in an extra $40 and upgrade to a modular PSU, it'll really clean up the case and help with cable management. The HX750 is $140 on Newegg, and the 650 is $120.
i have the cx 750 from corsair.
but if you want this 1 go for the cx 750m this is a modulair model.
and yes its enough for 7970 crossfire but a bigger psu should be better, also a psu what has les to do is better then 1 ho needs almost all his power on the 12v line.
