''GTX 580 SLI...........................850W .........................60A
GTX 570 SLI...........................800W .........................58A''
Is this the card themselves that takes 800/850 watt? or the whole system with them?
hi, you posted on my computer that it looks good to you.
http://www.computerforum.com/189228-need-help-first-build.html
I changed to the cooler master silent pro M600 600Watt.
would it be better than the corsair TX 650Watt.
I have not looked recently, I shall do it now (even though it's 2:30am and I need sleep, I'll do it just for you)
EDIT: It's there now. the AMD website states 550w, for amperage I have used a "safe" value until I can find some solid sata.
The GTX 560's TDP is said to be 180w, by the CEO of nvidia himself... that's for the card only of course.
Correct.
Also, I've been looking up that Corsair CX430. It's not a good powersupply at all. It can barely do 350 watts. All the primary capacitors are Chinese or Taiwanese, and it has zero PFC. The design is also similar in the VX450 and VX550 PSU's
So to anyone reading this, do not buy it. Antec and Silverstone have much better offerings in that wattage range, with quality parts.
Can anyone recommend a 400W PSU for a slim tower?
You'll need a Micro-ATX PSU by the looks of it.
http://www.newegg.com/Product/Produ...7151063&cm_re=seasonic-_-17-151-063-_-Product
its only 350w though
