Same old same old
Yeah I'm sure software can be had which can back up stuff up on a schedule. You could always partition your existing drives in your laptop - not sure...
Download a copy of the manual from the manufacturer. Some of the very low end boards don't have RAID support. I know my Foxconn H55M-S didn't
On a side note - long live this thread... lol
definately. Lol.
And it seems, talking via IM with a ASrock rep (surprising to me really) that the H61DE/S3 does not support RAID. It supports ACHI, but not RAID.
What? Instant Messaging tech support? That's new - I thought it was emails or phone??
Eh looks like if you want RAID with board you'd have to buy a RAID card and by the time you've forked out for a good one it would probably have just been cheaper and easier to get another board.
Actually not tech support. It was sales support. But they knew enough to tell me what I wanted to know. I told them I was wanting to buy the board, but I needed RAID. (small fib but got the information easy enough).
Yea, that is what I was thinking too. Probably grab a P67 asus, Gigabyte, or EVGA and use the extreme 4 for RAID in the server. Assuming that it does not decide to go AWOL and die again.
well it will be running the celeron, so no worries on overclocking. I will undervolt it again (it is stable at .950V) just to cool it down and save power. I will be using the 212 EVO with it too to keep it cool (should be right down chilly seeing as it never topped 40* on stock cooling).
Might seem like a stupid question at this point, but would windows home server work for this? Seems like it might be made for something like this.
well WHS seems to be built for this, and it is only $40 new. So it would not be as much as dropping a new key on windows 7, which I don't need. I guess I am asking is I should use the right tool, or jury rig a spanner to do the job.
If you think Home Server does what you need it to do, go right ahead. I've only ever used Windows Small Business Server really, so I haven't tried Home Server.
Sorry bout taking so long to get back to you. I got caught by the bell again. :(
Anyway, I was thinking that it would be better, especially for the price, because it is already setup to do what I want to do basically. (going off the following info).
Windows Home Server 2011, code named Vail[3], is a home server operating system by Microsoft and a successor to the Windows Home Server 'Quattro' operating system designed for Small Office/Home Office (SOHO).[4] Windows Home Server is intended to be a solution for homes with multiple connected PCs to offer protected file storage, file sharing, automated PC backup, remote access, and remote control of PC desktops.[5][6]
I might. Gunna wait on that though as I don't have enough to get a new board, 2 HDDs, and some RAM, as well as a case just yet.
I am chopped full of them. Problem being I always end up with 6 million ways to get to the end, but I generally end up taking a jagged coarse between 4 or 5 of them and get to some end destination 5k km from where I wanted to be.
Okay, had a idea, but questions... Should I go for RAM now, or go for a better board? Or maybe grab a case? IF I grab a case, then I can get a better PSU latter and be 2 steps closer to the Server.
Okay, so moving to a more on topic set of options. All of this is for the desktop unless otherwise stated.
RAM: Starting with 16GB again. Not sure of a farther upgrade. If I fancy a bigger upgrade, then I will just get the full amount then. But also the 8GB DIMMs are about teh same price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104292
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220638
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104169
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220619
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104340
which would you get? I trust these two companies. and they are small enough to fit under the HSF easily.
or I can get a motherboard.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130581
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128545
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188097
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130573
or maybe something else?
And I want to get a add in wireless card for the laptop. Not sure of the adapter I have, it is either express card or the IDE version. Just looking for something that does not overheat and is G/N capable. The integrated card is overheating a bit causing it to disconnect (which is not good at school).
What is series of your laptop? D630? I know any type of old wireless card. It can be PCMCIA (cardbus) i think. Should be Type 1 or 2.
yea. Latitude D630. The Wireless card that is in it is micro PCIe, but it is full height.
I would prefer to just replace it with a slide in card so that I don't have to worry about opening it up again. (though at this time, it is easy enough to pull it apart. Full disassembly in about 5 minutes and reassembly in about 7 minutes.).
Understandable, I found out it is PCMCIA cardbus. I have Belkin cardbus, D-link cardbus and D-link PCI-express. They're all good wireless card.
I hate to tell bad news. There isn't a lot of good cardbus wireless on newegg.com but amazon.com have many good cardbus. Or it can be found via ebay.
Here is my recommend of wireless cardbus.
http://www.amazon.com/D-Link-DWA-65...77118&sr=8-3&keywords=cardbus+wireless+d-link
http://www.amazon.com/Belkin-F5D801...77019&sr=8-1&keywords=cardbus+wireless+belkin
I don't mind buying from amazon. I get things from them all the time.
I think I will go for the belkin over the D link as it looks like it is smaller (height, not length).
So I guess it looks like right now my list of what I am getting is down to:
(1) Belkin wireless
(1) NH-D14 HSF
(1) SATA drive
(2) 12 cell battery
(1) floppy drive
(1?) wireless router. Might not get this, depends on what I figure out. as far as RAM and Mobo.
and then either RAM or a Motherboard. Not sure which, if either.
