!!!!!!! -- water cooling -- !!!!!!!!!
check out this image here
i guess the fillport thing is the fill tube on this image..
any good?
can u think of any others? like better ones? i mean, like let's say with the fill tube in between rad and pump, or any improvements..
i'm just speculating..
hey, i did the math here..
Pump-89.95
Radiator-59.95
CPU Waterblock-55.95
Chipset Water Block-29.95
VGA Water Block-63.95
Fillport-13.99
Hose Clamp (for pump)-1.89
+1-1.89
Thread Barb (for rad)-2.49
+1-2.49
total-322.5
add another 50 bux and get a whole H20-220-APEX-ULTRA-PLUS system from the manufacturer. with a manual, extra tubes, installing tools, infamous MC8800 (does anyone know if they even work, anyways? lol), and a bottle of cooling liquid. furthermore, with warranty and support.
lol, didn't you say something to me about control and kit being more expensive? jus messing with you
:) blah blah blah :) you get a lot more with the one I suggested, he doesn't need to buy all of it at once
any good?
hey that is what I said :)
there really isn't any improvement that can be made
I disagree but whatever it's not going to be my system.
Pump89.95Radiator59.95CPU Waterblock55.95Chipset Water Block29.95VGA Water Block63.95Fillport13.99Hose Clamp (for pump)1.89+11.89Thread Barb (for rad)2.49+12.49total322.5
yeah but that is only a 2 fan rad, the one i suggested is a 3 fan rad
i think that's the perfect system here. cuz the CPU actually produces the most of the heat, right? so now i need a couple of those fork-shaped splitters too..
keep enhancing guys.. brainstorm!!
Well the 2 biggest heat producers are obviously the cpu and gpu which is why I would want them both getting freshly cooled fluid as opposed to the gpu getting fluid heated up however much by the cpu. Again preference.
theresthatguy, man y do u disagree? do you think that a whole manufacturer-packed kit would be better? like one of these H20-220-APEX ULTRA + ?
I just meant that I disagree that the setup couldn't be improved from cpu->gpu-chipset setup.
gotcha
jesus man, is it a SLI sys? what is that?? GGGGGGGGGOd!! MORE DETAIL PLZ1!!!!
SYSTEM SPECS
Main Components
Mobo: Asus Striker Extreme
CPU: Q6600
GPU: eVGA 8800GTX SLI
RAM: 4GB OCZ FlexXLC PC2-9200
Audio
SoundBlaster Fatal1ty
Storage
LSI Logic Dual Channel Ultra-320 PCI-Express SCSI Controller
580GB 147GB x 4 RAID 0 Fujitsu Ultra-320 15K RPM
750GB Seagate SATA-II NL35
500GB WDC USB
Plextor PX-755SA w/Lian Li SATA USB External Enclosure
Display
Dell 307WFP-HC
Spyder 2 Pro
Peripherals
Logitech G15 Keyboard
Logitech G7 Wireless Mouse
PSU
Ultra X3 1000W
Watercooling
CPU: Swiftech GTX
GPU: EK 8800GTX FC x 2
Mobo: EK Asus NB/SB/Mosfetts Set
Pump: MCP655 x 1, MCP355 x 2
Rad: PA120.3 x 2, PA120.2 x 1
Res: Swiftech MC-Res x 3
Fitting: Koolance Compression
Tubing: Tygon 1/2", 3/8", 1/4"
Fan: Yates (Lots of It)
OS
Vista Ultimate x64
