lol. dont worry if you put it in the circle socket then you will be fine but since your grounded any electricity will go through you to get to the ground.
so yeah i would go with connecting it to the case if you only have the wrist strap
I believe phantom is correct, I don't know from personal experience though as I've never felt the need to used one.
im doing this on my bed, is this a bad idea?
bad idea. you should do this on a hardwood floor if you have it. or any other flat surface that does not have carpet.
i only have 4/6 of those specific screws that the thread says to use. I dont know what to do
damnit, it says i need 9 of those screws, wtf
