I hope you have McAfee Total Protection 2009, if you don't, then that's your problem.
McAfee is the BEST
McAfee is the BEST
McAfee is the BEST
If it hasn't completed after 23 hours, it isn't going to. Reboot the computer and post an update (and C:\ComboFix.txt if it exists)Ok, so it's been 23 hours since my last post and there's been no progress
The screen still shows "Preparing Log Report" etc...
What are your thoughts?
No further progress since last post
No HDD activity or blinking lights
Just did Ctrl Alt Del though and it shows Find3M application is running
Performance shows CPU at 1%
Restarted in safe mode and CPU is now showing 99% at "System Idel Process SYSTEM"
In my hard drive is a folder named "1Combo-Fix"
(I downloaded all three links you gave me previously and remaned them as Combo-Fix with either a 1,2, 0r 3 onfront of them just incase any of them didn't work - I ran number 1 as you've already guessed)
If I open folder "1Combo-Fix" and there are loads of files in there
One of the files is named ComboFix and is in notepad form
I opened this and believe this to be the log you are looking for?
How do I go about posting this on the forum? asit's an awful lot of info if I end up having to type it all up!
I reconnected my external drive but it still doesn't acknowledge a connection
Can I save the file to the CD I saved Combo-Fix to?
That way I can open it on this computer and copy the log onto the forum
How do I save the file to my CD, as my mouse is still disconnected?
