My final setup! It's complete, needs looked over (make sure everything fits)
If you have the budget.... i would go this this monitor,alot higher res and ~$30 more:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236053
Power supply, i would go for something like this, its around $20 more, but corsair power supplys are some of the best, while raidmax is kinda iffy.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
By the way.... your going with an xfire mobo, so you might wanna go with an ati graphics card incase u wanna xfire in the future, or switch to a cheaper mobo to save some $, or go with an sli motherboard incase you wanna sli in the future;)
Again wow, thank you guys so much for the help, ive changed the mobo, and yes i dont think im going to change to intel because as thandakid said im way way over my budget. I was wondering if theres any way i can lower my total but still have the same quality stuff, or less it doesnt matter, i dont need the ultimate rig, its my first one so ya 900 i thought was never gonna happen -_- whick it did :o
KiD [720];1229774 said:
Is 635W enough for a power supply, for all the stuff i have
Which psu are you looking at that is 635w? Depends on the power supply. If you take a look at that corsair 650w i linked to above though then that will run everything just fine plus have plenty of breathing room for upgrades;)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226002
thats the power supp. im looking at.Im just trying not to go over 930, which i did, so now i have like 200 comin from my own pocket, i was allowed a 700 dollar budget with some slack if i covered overage
Updated first post, check and see if i can change anything that will run my total down, and i can still get the same quality part, even if its not as good as the part that was replaced...know what i mean?
I dont think the motherboard supports this CPU as the CPU has Socket AM3 while the mobo supports AM2+ max .Correct me if i am wrong
I Think it will work
But before ordering wait for anyone else to comment also on it I think it is this way but i may be wrong
Ok, i wouldnt recommend buying that 4850 cuz its an SLI mobo, plus the gts250(9800gtx+) performs better anyhow;) Also, i would recommend changing the cpu from a 710 to a 720, even though you wont get an unlocked multi it should overclock similarly:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103648
Change that memory to ddr2, the nforce750 board is ddr2, here is a link to a nice patriot dual channel kit(patriot makes the best memory imo):
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220314
or if you dont wanna deal with a rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227362
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182149
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
The motherboard you have and the CPU you currently have on your first post is compatible.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M3N72-D&product=1&os=25
This is the CPU support link for that ASUS M3N72-D motherboard...the AMD Phenom II X3 720 will work as long as you have 0603 BIOS.
You will have to save the BIOS file from Asus website and put it on a flash pen memory device. When you first boot the computer...use the Asus EZ Flash tool and update the BIOS. It really is simple, nothing to be worried about.
_________________________________________________
The DDR3 RAM you added will not work.
so AM3 Socket CPU works in AM2+ mobo also
AM3 cpu will work in a socket AM2 aswell(essentally as long as there is a bios update and it is an amd chipset), thats why amd at the moment is the best choice, intel has no backward compatibility between i7 and 775, while i could get my friends 2 year old 680g $55mobo and put a top of the line phenom II in it and it would work just fine...
