Folding@Home: CF Official Discussion Thread
The utility works...kinda cool actually:cool:
This is a TechZine article waiting to happen...let the testing and recording begin:D
Core clock: 729MHz
Memory Clock: 1152MHz
Shade Clock: 1458MHz
Voltage increased from 1125mV to 1200mV
Temp: 55c:good:
And folding wide open with no issues so far. I am going to play some Call of Duty later and see what happens. I have never been able to get above 700MHz before...nice app;)
How do you get that layout for your display? I've been working on a project for about a day now and all it shows is a 3D molecule with a black background. Do you need to use the console version?
I've just started folding infrequently on my 8800. A little bit here a little bit there, finishing work loads of course. Is it worth folding on my E8400? While i'm folding it only uses about 4% average on my CPU.
im having some problems with this, i downloaded the windowed version and then read about the multi core system one, so downloaded the console one. I tried setting up the multi core thing as said but the second command line isnt working, it tells me that -Console is a bad argunment :confused:
could somebody help me to work that out please?
You might not want it running on both cores. I have it set to utilize 100%, so the program uses one of the cores while I use the other for normal tasks. If anything, 100% on one core is too high for me, I'm glad I didn't get the second core working.
You could always run the GPU client as well, I'm running both at the same time right now.
aaah right excellent ok then, well now i have another question, where can i get the gpu client :P ?
Just make sure the Machine ID's for the different clients are different. Like, make your CPU client ID 1 and GPU client ID 2. If you want to run F@H on both GPU's you need to disable SLI and run 2 GPU clients, each with different machine ID's.
excellent, alrighty thankyou :) i have got both CPU and GPU up and running at the moment, thanks for the help getting it all working
Hey, I just joined today. Quick question> How are you scored? It says that I have like 13% done of folding but so far I'm kinda lost in the whole thing.
Anybody been getting a lot of this the last couple days? Every couple WUs I can't connect to the server for some reason:mad: I left my computer on for a good strong folding run of about 14 hours today...only folded about 1/3 of the time:eek:
I haven't been paying attention lately... usually, if you see that, you just exit out of the client, restart and then it reconnects to the server.
We have < 10 people folding reguarly at the moment. Pathetic, considering all the sick hardware available in this community. :angry:
I made in the top 10! :D
Congrats mep916....2 million points:eek:
Thank you sir. If electricity wasn't so expensive in my area, I'd prolly be pulling in 20,000 PPD by now. That was my original plan until I moved. :(
Congrats to you as well.
Is there any way to view past log files?
I had a few F@H crashes this weekend and I made a few changes to my system. The display driver would crash and I would have to start a work unit over again. I found out it was caused by a Windows update and I uninstalled it. I think it's working good now.
I left my computer on while I was at work for about 12 hours to slam out some WUs. My wife shut down the computer right before I got home...the log file reset and I want to look at the log file from today and see if it crashed:(
