I have 5 fans placed in my case with and 4 additional smaller ones that blow on my hard drives. 2 120mm intake in the front. 1 80mm intake in the side. 1 120mm that blows out the back and a 80mm that blows out the top. My case is also a cube that has a smaller area inside than a full tower. The airflow in there is high. Everything else in my case is really cool. Just started playing crysis in enthusiast settings with an easy 25 frames ps average. Gamer was around 38-40. Bout to overclock my processor a little bit. Thanks for helping me out up until now I had a ati 9600 for 6 years and then a 4670 for 1 month and now this. Its awesome.
Funny thing happened though. I went to power my computer and it didnt post so I had to turn off the PSU manually. I could then hear the PSU making high pitched hissing noises that I guess are capacitors. I can now only power the psu on its own and even then the fan looks like it is spinning really slow. If it is plugged into a motherboard it will not turn on. I ran to frys and picked up a coolmax PSU. Probably not the best brand but I didnt want to spend a ton since I will hopefully be getting a replacement on my Xclio.
