Hmm... your TRAS setting should be 24 for CAS9 I believeWill add score now unless you want to fix it and re-run
I don't know if i should be adding anything that says ES in it >.>
you're going to be limited by your max BCLK soon![]()
It's not the first time I've had an ES cpu, probably won't be the last.
You mean the chip or the board? This board hit 240 base clock by the previous owner, and he was only an intermediate overclocker at best.
