Absolutely, but some standards
specifry that a 'rail' will be dedicated to the CPU and thus a simple addition of the rail amperages (12V) is not correct. I would suggest we recommend for PSU's presented as 'multi rail', the user should deduct 12V+1 as a rule and then we recommend a min amperage from that.
A good example is a 500W PSU for example with 2 x 16A rails on the 12V. Apart from immediately indicating and older design (when less components drew from the 12V rail and more on 5V or 3.3V), if the particular design standard specifies an isolated 12V+1 rail for the CPU, this pevents the rail 'sharing' load and thus effectively means the whole 12V rail system minus the CPU needs to run on the remaining (12V+2) 12V rail. 16A isn't enough for a system with a PCIe card - and this is without a doubt due to quality (efficiency, active power factor control, MTBF blah blah).
My point is, that for some PSUs, the amperage and wattage ratings don't tell the whole story. I think this problem is important in the 400 - 550W category from what I have seen and the above point many need to be included in that section. These are the PSUs that you see go pop and take a nice new 5890 with it, or just basically give intermittent errors forevermore. Simply because it 'looked like it had' 32A on the 12V rail.
Finally, if we are dedicating such a fine resource such as linkin for this task, (cheers mate
), may be we should also consider making links (with references) to other excellent sources>
Some here:
this one by Mark Allen is amazing
Im not saying make a link only, pull out the occassional paragraphy and reference it. Pics also. If you don't like pointing members away from CF, then simply reference the author (username/avatar).
It could look like this:
No point reinventing the wheel. :good:
What would also be cool, is if we could have the top 10 or 20 FAQs, frequently asked questions. We could hyperlink to a referenced paragraph for each. CF's web host/admin, should be able to pull the top 10 search terms or phrases which could inform us of the right questions to use. This would increase CF.com in traffic and thus revenue too.
There are quite a few boys that would probably help too, and of course that includes me.
Also by Mark Allen -
Sorry for crapping on.
