tech savvy
Well the new Avg sucks, it wants you to reboot after every update
i dont know which AVG your using,lol. i dont have to.
I think it's a reference to Win98's habit of asking you to reboot if you so much as looked at the Control Panel icon.Codename "AVG 98"
Anyway, I have the new AVG and it doesn't ask to reboot after every update. I get those reboot notifications every couple of weeks or so, and I have set it to update daily.
Its a shame about what AVG has done, they used to be the "go-to" antivirus company.
AVG is okay. They did me dirty a few years ago, a glitch they've most likely solved since. After an hour or two of reloading a fresh XP installation I ran AVG- not that it needed it- just to let it do it's thing. After the scan it reported that it had found definitions that could cause harm if deleted. Was it a virus? Was it a trojan stuck into the torrent copy of XP I was using? IDK. It bsodon reboot after I decided to give it the go ahead. I've since turned to PC Tools Dr Spyware offered free from Google. That along with MS Security Essentials. That's not all I use, just the ones I leave to run on a customers computer. Other anti-viruses have different strong points.
I use MSE and Avast myself.
Right now, Nothing (I'll be switching to an SSD soon)
But usually Avast!
Although I remember 4ish years ago, when it was a piece of absolute junk!![]()
