jonnyp11
I'm with you here. Any news on the release date?
Look like 2 above your post, the 7970's are out and several have sold out on newegg
I thought they were going to use xdr2 RAM instead of GDDR5?
I thought so too, idk what happened
They should have designed the exterier of this card a bit like Asus Matrix. The cards just don't look like a 7970.
Not me.
I will be waiting to see what Nvidia come up with before selling off my 580's.
You telling me that gtx 580 sli with an oc of 1Ghz isnt powerful enough![]()
So if you have a gts450 like your sig says, you aren't running 5760x1080.
Lol, fail.
Do tell why it's a fail, because Nvidia surround doesn't work on 3 monitors unless you have 2 cards.
Actually if I run BF3 @ 4960x1600 with all the eye candy turned on then it isn't enough (even @ 2560x1600 it can be a little jumpy). For most other games I would say my graphics solution is adequate.
I treat my computer as a hobby rather than a necessity.
I didn't see one person ask the OP what resolution he runs.
Some people recommending a 3gb gtx580 because 1.5 isn't enough..........
Well guess what people, if he's running 1080p like the 98% of the rest of us are, even a gtx570 1.25gb is overkill for any game and plenty of memory.
noobs![]()
... even a gtx570 1.25gb is overkill for any game and plenty of memory...
noobs![]()
