|Official| Smiles Benchmark 2.0 Ranking Thread! (new version :P)
Virssagòn
There's a problem that we need to sort out - average score needs to be worked out by dividing the total score by 4 not 3; otherwise it's not an average. I know you're going away again so I'll take a look at it and try to correct it.
Don't change anything in that calculations. I made the calculation of the points the most fair. It's not only based on the average. I only want you to make it run twice when I'm away...
spirit
Moderator
OK. That's pretty easy to do I have an idea of how that can be done. :)
Virssagòn
When I got the automatic site up and running, I maybe gonna split them back. But to make it easy for us, we make 1 benchmark now.
Jamebonds1
You should making stress test like Hard drive and Flash USB, burning disc and reading disc, GPU, or stuff that make it more stress and rising heat from CPU. :)
spirit
Moderator
Sadly with Visual Basic we are a bit limited with what we can do. Coding a CPU benchmarking application in VB.NET is pretty tough as it is and we've had a few issues.
Virssagòn
yeh, I was planning to make a stability or stress test. But hadn't enough time.
I'll make it when I'm back!
wolfeking
banned
no offense smile, but I would stick with one project at a time. What you have is good, but not quite perfect. I would make it perfect before moving on.
Virssagòn
my program is 1 thing, I want to make it somebit bigger.
But vista gonna make it run 2 times and we'll see then.
wolfeking
banned
you through me when you said you wanted to make a stability and stress test. It sounded as though you wanted to make a new program to run them.
FuryRosewood
Dunno, seems a bit off, i kinda am disregarding the number in the corner, every time i ran it it did not change...and comparing to Wolfe....my i7 is bone stock.
G80FTW
Maybe this question has already been answered somewhere in this thread....but too many pages for me to go through:
What exactly does this program do? Does it just do like floating point calculations?
Heres my score I guess, feel like I did something wrong somehow:
G80FTW i7 970 3.20GHz (3.34GHz turbo, stock clocks)
MyCattMaxx
Got my HP w/FX-4100 going again.
This bottom of the line MB won't hold voltage well and the cores won't stay locked on the multiplier, I watched the speed dropping to 3.2Ghz while the test was running.
I ran the test a few times in a row and this is the best run.
FX-4100 @3.6 (stock) 8gig 1333Mhz ram.
spirit
Moderator
This version is not finished yet remembered, I'm not sure why SmileMan even released it into the wild at all. There's still some work that needs doing on it.
Jamebonds1
I was going post of my benchmark but my computer is died. Killed by water drip from top floor :( (I'm in rent bottom floor house BTW) Anyway i got 59000 point benchmark.
spirit
Moderator
Bad news about your PC, James. I thought your insane overclocking would have killed it first! ;)
spirit
Moderator
So hang on water dripped from your ceiling and into your PC (through a vent I guess?) and now it won't work at all, correct?
Jamebonds1
Yeah. It is come from top floor. I think someone had spill some water or something. Anyway I and my roommate will talk with owner. I'm look for best Gigabyte motherboard LGA 1155. Maybe i7 LGA 2011 :D
