It's pretty good. In bigger cases, air cooling would give you about the same sort of results, but remember though that your case is tiny and airflow isn't the greatest, so air cooling wouldn't work as well as water cooling has for you.![]()
Here are some quick results:
Idle
and 100% load:
I think it's not bad considering the size and how much stuff is packed inWhat do you think?
Seems a bit warm for watercooling at only 4.5ghz. I mean, my 3570k maxxes out at high 70's using a small 2 heatpipe 92mm air cooler, with a better air cooler it would at 70c or less. But then again, my 3570k takes less than 1.30v for 4.5ghz. I would have thought 60c or less though with a full loop at only 4.5ghz.
Now you got me thinking. I will try to lower the voltage somehow. Is there any setting in the BIOS that I could turn on or off for better stability?
did you not do a manual overclock? did you use the mobo's pre-set ones or something? those tend to have a good bit extra voltage to ensure it is stable for everyone, not the minimum amount that is needed for a stable overclock on your partivular chip
Yes, I have, I might just overdone with the voltages.![]()
Yeah those temps are pretty high for that OC and voltage. Pump being not enough is definitely possible since you are running CPU and GPU cooling. But another possibility is issues with the CPU block mounting. What thermal paste did you use? How much did you use and how was it spread? And then, is there sufficient clamping force on it?
Also just curious, why do you overclock the base clock? Just leave that alone and use the multiplier.
Oh and on the folding, Intel burn test puts the absolute most load on the CPU possible for the absolute hottest temps. Folding doesn't stress the CPU as much (even though it still says 100% CPU usage).
Hmm, usually paste that comes with heatsinks is crap. Was it pre applied or a stick to put it on yourself?
What method did you use to spread the paste?
OK, I tightened the screws a bit, tested, untightened a bit and tested. Makes no difference whatsoever.
So it's either thermal paste that needs changing or the pump. Or both. If so is there any good and small pump that is very efficient and quiet?
It came in its own little tube. I applied it using an old credit card. Put about a pea size drop in the middle and then spread it thinly and evenly. I find the temps a bit odd as the CPU block was consistently one of the best in test this year, in various sites and magazines.
