Ok, calm down. No need to start using bad language. All we can do is suggest to you what to do. Its up to you to either follow our advice or not to.
You have some very flaky software installed on your system, it doesn't matter when you installed it or when the issues started happening.
I've suggested a way for you to try removing those 2 entries by using revo uninstaller.
Another suggestion would be to do the following.
Right click on command prompt and click on run as admin.
enter sfc /scannow and hit enter. This will check for altered and missing system files. You may need the windows 7 install cd in the drive to complete the process.
