Post A Pic Of Your Pc Here :)
JasonPDK
Great stuff Jason! (I feel like I'm talking to myself now haha, my name is Jason.)
Can I ask you a question though: what's your opinion on the Z87X-UD4H? I've got a friend who is doing a new build at some point in the future and I was putting a parts list together for him from Novatech but I saw Novatech didn't stock the Z87X-OC (which is the board I wanted him to buy), so I recommend the UD4H instead. Is it a good board?
Haha, isn't it great? :D Thanks Jason! :p
It's a great board, I have no complaints about it! The Z87X-OC is probably a slightly better board, but overall I'd say they're more or less equal.
And like 87dtna said, the BIOS looks great, took a while to get used to it though :p
87dtna
Thought you say 750 watt psu is overkill. :)
It is for my current setup, but I used to have an I7 860 overclocked to 4.2ghz and a gtx 295 on this PSU which consumes probably 200+ watts more than my current setup. I saw no need to downgrade my PSU so I can keep my options open for possible SLI 670's. But yes on my current setup even a quality 500w PSU could power it with no issues. But SLI would add another 200 watts. Your setup can not even SLI because of motherboard limitations, so your only options are 3770k and the 680, so yeah a 500w PSU would be enough for your setup no problem.
I'm also going back to a full water loop so thats gonna be another 50w too between the pump and fans.
Hyper-Threaded
Wow that's a quite mess you have there lol.
Better?
Soon the receiver will be on the empty shelf and two tower speakers.
S.T.A.R.S.
banned
S.T.A.R.S.
banned
You can use it at 90 degrees quite alright. :)
Nah I don't know.They can fall very easily when you are putting them in right in the middle of tray closing and then the disk can be ruined lol.
I will never use my drives on 90 degrees lol.
Talking about 90 degrees,I have also noticed that hard disk drives last shorter when being used vertically instead of horizontally.
Geoff
DVD tray's have small clips on the side that prevent the DVD from falling out when used at 90 degree angles, the same is done on consoles, most of which are mounted upright.
spirit
Moderator
I had a PC which was mounted at 90 degrees and the DVD drive was fine but yeah the HDD didn't last too long IIRC. Could have just been coincidence though,
S.T.A.R.S.
banned
I know.But every time when the tray STARTS CLOSING,the damn disk just falls out lol.
Then in my case I had MANY coincidences lol.
my h110 is in front of my fractal desing case.
today i put 2 other fans in front, and i put the Original h110 fans at the back of the h110, so its in push-pull now
pretty happy with the cooling now.
S.T.A.R.S.
banned
NEWS:
As I am writing this right now,my last HDD is being erased with the Kill Disk 7.1.It should be finished for about an hour.After that I will of course need to create a new partition on it and format it in Disk Management what will take 1 and a half hours.And after I do that,I will turn off my computer and the UAC data device and after that BELIEVE IT OR NOT...THE MAIN UAC DATA COMPLEX CENTER WORKING ENVIRONMENT ROOM STAGE 3/3 IS FINALLY GOING TO BE FINISHED 100%!!!
And my dear people that means that I am completely finished with my whole work 100%!!!
So during this month or at the beginning of the next month I will do my best to make a nice music video of my small UAC data complex center working environment room and show it to you all just as I have promised. :):):)
I really hope you will like my setup...I surely do!!! :D
By the way the quality of the video might not be so super awesome because I will record the video with my crapy Toshiba camileo P-10 camera device.I don't have any better camera device at the moment so that one is my only choice lol.
After I make the video,I will also make few pictures (for those who prefer pictures over the video lol).
Now...
I am going to make 2 videos.Video 1 will show everything as fast as possible using some cool music but without explaining the details.It will be approximately 2 or 3 minutes long.
Video 2 will also show everything,but a lot slower and a lot more detailed.By A LOT MORE DETAILED I mean that I am going to explain what is used for what,all the specification details and absolutely everything else.That video will be longer...approximately 15 to 20 minutes long.It really depends since there is a lot of stuff I wanna show you and explain you lol.:D
So...this is it for now,but you can expect these 2 videos soon.;)
CHEERS!!!!!!!
