how can this be all stock default clock is 1084, this card runs at 1109 and also a little higher on the mem, so that's no stock.
Sorry that I beat your score by 40 point![]()
Because I have the FTW version, so it came overclocked. These are the stock settings on the FTW version of the 680 that I have. I actually have not overclocked this card at all I dont think. Havent really had the need to.
Even so, Im not sure that the whole 25mhz overclock is really significant on this card. I got it for the 4GB and when I bought it they did not have a standard 4GB version available.
Your also running a much overclocked more efficient processor than I am along with having higher clocks on the video card. So with that said, I am not impressed by your extra 4FPS
EDIT: Looking at that 280x, it looks like it scales almost perfectly in performance with my 680 despite its higher memory bandwidth.
I can tell you that I had the ftw also, and its default clock speed is 1085 on the core, and not 1110 like yours, I now about the different cpu, but I can tell you that in valley the cpu doesn't do much, I can run on 4.5 and have still the same points.
so if I put my card on 1100 on the core then I have less on the core then yours, not saying that the gtx 680 isn't a great card.
but I shell put it on 1085, and 1515 on the mem.
and like you say in the 2013 benchmark the boost speed of the 680 is higher then 1175, it runs over the 1200 so technically that's what your gpu should have been under load
lol, haha but start valley and look at the top right corner you see white letters and numbers when benchmarking, there it will say what the core speed is under load.
it will be higher then the core boost showen in gpu-z
You're right. Benchmark on top left is never accurately.
In fact, I would choose EVGA or Gigabyte for better benchmark.
Haha, I think I have some really good memory on this card
My FTW edition comes with a 50MHz factory OC on the memory and a 91MHz OC on the core, so I'm pretty happy that I've got the last ounces of power out of the card
Overall I have a 151MHz OC on the core and a 325MHz OC on the mem, which is effectively running at 7308MHz
Most users over on Hard Forum are hitting between 1200-1300MHz boost clocks on the core and are really lucky to get 7GHz effective (1750MHz) on the mem, it looks like I have a not so good core but awesome memory lol
