Okedokey
Well-Known Member
I built a Pentium G3258 rig this year and runs at 32 degrees Celsius. 60 degrees Celsius is way too hot for an idle for most rigs considering even people using i7s try to remain 40 degrees Celsius or cooler. Check the following and respond: How much dust is the system? How many vents and fans does the system have? Is the computer on carpet or crammed into a shelf? Do you have it on a shelf? How close is to a wall?
You cannot possibly say that without mentioning the ambient temperature!!! Nonsense.
The only way you can maintain 32 degrees C is if your ambient is below 20oC, otherwise you break several laws of thermodynamics. That is working on the fact that 10oC delta is considered the golden temperature difference for watercooled systems, so you are not going to get that on many aircooled systems. So, yeah, it was a cold room you were in.
60oC is not hot and is a full 40oC under the TJ max.
We have already solved the problem, my question is how much of an OC can I get with the Hyper 212 Plus
So you have bought a new cooler??? is it on it yet. People have got to 5GHz on that chip, however I wouldn't think you would get there unless you have a really good motherboard and RAM. I would aim for 4.6GHz and then drop the voltage until unstable to manage the temps.
However since you have an unbranded 460W PSU, I wouldn't risk overclocking anything.
