Post A Pic Of Your Pc Here :)
Laquer Head
Well-Known Member
@RujoKinJal all good now man.. looks good..
cable management is easy.. grab some zip ties and use the space in your case to try to tuck away excess wire.. It's not too hard and it'll look awesome, and breathe better
tremmor
Well-Known Member
Like the idea also Shane of the wheels. Have my tower on the table. Was at Harbor Freight
and seen the wheels. Didn't do it. would be blowing out 3 or 4 times a year on the floor.
Will keep on the table for now.
Shane
Super Moderator
Im so glad i done it,It makes it so much easier now to pull out..i did at one point have my case on the Desk but it used a lot of space and i needed that space for a second monitor..so on the floor it went. :D
For my next computer build though,Definitely going to look at going small form factor/Mini-itx.
As quiet and less fans as possible.
External DAC/Sound setup.
Intel_man
Installed my monitor mount today. Freed up so much space.
Intel_man
Thanks man! Yea Monitor Mounts are great. I did a lot of research on them before grabbing Amazonbasic's dual monitor mount which was basically a rebadged Ergotron LX dual mount, but for way less than the actual Ergotron.
Calin
Well-Known Member
Sorry for the double post but since a lot of people complained about the pic quality I took the rig to the kitchen where I have much better lightning and took some pics.
