Before or after the 3 way GTX 1080 SLI setup?will buy new ones, don't worry
Ok, I don't have THAT kind of money lmao.Before or after the 3 way GTX 1080 SLI setup?![]()
You can't be far off though. How about two 1080s?Ok, I don't have THAT kind of money lmao.
Maybe if I save money until the 1080 ti comes out I'll be able to get 2 of themYou can't be far off though. How about two 1080s?![]()
Need 4 of them to make it worthwhile though.Screw the ti, get the Titan X replacement.![]()
What if the Titan X was the last Titan and there is only gonna be a 1080 ti with a fully unlocked gp100?Screw the ti, get the Titan X replacement.![]()
Yea but he cheaped out on his CPU. Should've bought the 5960X if he wanted to run Quad SLi.Need 4 of them to make it worthwhile though.![]()
Are you saying he couldn't run the quad SLi with his CPU?
Yep. SLi requires a minimum of 8x per slot. So the max he can run is just 2 way SLi.Are you saying he couldn't run the quad SLi with his CPU?
The 5960X has max 40 pcie lanes while the 6700K has max 16 pcie lanes.. thats why
However the 5960x is like $1000 usd
Worth every penny.
Its ok, if you don't want to get the 5960X, buy the upcoming 10 core hyperthreaded 6950X.STOP giving me reasons to blow mad skrilla bro...LOL
Its ok, if you don't want to get the 5960X, buy the upcoming 10 core hyperthreaded 6950X.![]()
WOW! that is nuts.
So does my new i5 6600K only have 16 lanes as well?
