Geoff
Just make sure you are flashing the correct SuperSU version to your tablet so it doesn't happen again. It may be easier to simply flash a pre-rooted ROM.IT WORKED!!! THANKS SOOOO MUCH!
should i also flash root via adb?Just make sure you are flashing the correct SuperSU version to your tablet so it doesn't happen again. It may be easier to simply flash a pre-rooted ROM.
No you flash it through TWRP.should i also flash root via adb?
No, you use adb to get custom recovery, once you have custom recovery you flash all zips through recovery.should i also flash root via adb?
I used that on my HTC Thunderbolt lol
I cant download twrp from there website, anyone have direct download links?No, you use adb to get custom recovery, once you have custom recovery you flash all zips through recovery.
https://dl.twrp.me/flo/twrp-3.0.2-0-flo.imgI
Lel :3
No. That's not an issue. All that means is TWRP doesn't check for root and ask if you want to install SuperSU (like I asked you last time if that's how you installed it).umm, after i installed TWRP, when i first boot into it, it says: swipe to allow system modifications, so i swiped. than it said "Team win does not offer rooting" could this be my problem and if i flash root again will iy soft brick my nexus again?
I need it for the nexus 7 2nd gen 32 GB lte and wifi model.
Help! When i start super su, it says there is no root binary installedNo. That's not an issue. All that means is TWRP doesn't check for root and ask if you want to install SuperSU (like I asked you last time if that's how you installed it).
Just flash the correct SuperSU.zip for your device through TWRP.
Stop making new threads. Just stick to one thread.
https://download.chainfire.eu/921/SuperSU/UPDATE-SuperSU-v2.65-20151226141550.zip
Please tell me you didn't just install SuperSU from the Play Store and thought it would do the same thing.Help! When i start super su, it says there is no root binary installed
Great, im soft bricked again. so, i downloaded supersu from chainfire on my pc, i copyed it to my nexus. i booted into twrp and installed it. i downloaded flash fire after it said root binaries not installed and it said supersu needed to be updated. so i got a later version from chainfire and installed via TWRP and now im soft bricked again.Please tell me you didn't just install SuperSU from the Play Store and thought it would do the same thing.
Tell us step by step what you did to try and get root.
too, late. i already flashed back manually. thanks for that toolkit for next time i soft brick it......can you tell me whats happening every time i try to root my nexus?
You're doing something wrong. So just use the toolkit to unlock and root your Nexus.can you tell me whats happening every time i try to root my nexus?
does it matter?You don't need Flashfire.
What are you going to do now that you have root?
Does it matter?And you plan on doing what with Root access?
