John may I suggest a change? That EVGA is pretty bad. Put $10 into it and you can get a good S12II Seasonic. https://pcpartpicker.com/product/4Vzv6h/seasonic-power-supply-s12ii430b
If you think your build is bad, why did you post it in the first place?
I use the evga in client builds and have no problems with them. I either use the evga or corsair cx430 whichever is cheaper and easier to get at the time.
But you have to realize the higher the tier, the better for high end machines. We are only dealing with an entry level pc here, doesn't need anything special.
