Agent Smith
Well-Known Member
I can vouch to a case making a difference. With the way I have my case fans, air is sucked in on top over the CPU cooler and my temps stay pretty damn cool. I have to wonder if it would be even more cooler with the heat sink using a push/pull config.
Looking at your case you do have fans on top. So that's probably why. Tell you the truth, that may be a bear to install the 12v 8 pin MOBO connector if it's like mine on top there with those fans.
Here's where mine is located.
