yup it will help with your cpu score to turn a few background processes off, and some people use both the hotfix and the optimizer and report good results. you will have to alter the registry if you want cool and quiet to still work.Thanks for the responses, sonds like the 7300 GS being the culprit is the consensus. I will wait until I get the new card and post the new numbers.
A few things though: TommyCompton suggested shutting down a lot of other stuff to run the benchmark; is that helpful?
Also, I have the most recent AMD Dual Core Optimizer installed, do I have t worry about the xp/dual core "hotfix" issue?
Atleast it beats tommy's Cpu Score.![]()
No I dont think it will. Not Unless your CPU pulls something like mines in that 3dmark. You will need x2 4800 or fx60 or higher for it to work.
What is 3dmark i dont understand so you guys are saying it improves the cpu or what???![]()
[-0MEGA-];420031 said:So what is your FX-60 clocked at?
