3DMARK06 Scores Here
My SM2.0 (what ever that is) is 150 nad my CPU score is 772. score 322 I think.
YAH I'M KICKIN A**!!!!!
Thanks for the responses, sonds like the 7300 GS being the culprit is the consensus. I will wait until I get the new card and post the new numbers.
A few things though: TommyCompton suggested shutting down a lot of other stuff to run the benchmark; is that helpful?
Also, I have the most recent AMD Dual Core Optimizer installed, do I have t worry about the xp/dual core "hotfix" issue?
yup it will help with your cpu score to turn a few background processes off, and some people use both the hotfix and the optimizer and report good results. you will have to alter the registry if you want cool and quiet to still work.
Well I got my new card (XFX GeForce 7600 GT) and it made all the difference.
My new marks, with no overclocking, are:
3D Marks of 3496
SM2.0 of 1419
HDR/SM3.0 of 1301
CPU Score of 1655
Any single 7900GT's above 6000? I'm getting one soon so...
I read some reviews about oveclocking them and saw some benchmarks, dang, vRAM from 1320MHz to 1800Mhz, now that's a damn high overclock, better than a single stock 7900GTX, 100% of tested cards reached 1650MHz. Highest overclocked one was from Club3D btw
No I dont think it will. Not Unless your CPU pulls something like mines in that 3dmark. You will need x2 4800 or fx60 or higher for it to work.
I rarely/never play any other game except CS:S so I don't care (maybe a bit of FEAR), but on 3DMark05 I'll get above 10k for sure. As for my CPU, clocked at 2.8GHz it's rated as 4400+, lol, my cpu is fine, don't do much multitasking so no need for dual core for now as CS:S is not optimized for dual cores, yet.
