massahwahl
Does the VLC player work on linux? Might it be a better idea to use Linux MCE rather than Vista since linux would not eat up as many resources? Is the 8800GT compaible though?
You can't use the DVD menus with VLC...? I guess as long as that doesn't bother you.
Hmm, didja read the specifications and reviews of that GFX? It's passively cooled, and some said that it overheats to 100C+... So I don't think such a small case + such a hot card will make a good system.
Since when? I watched 'I know pronounce you chuck and Larry' last night and it has full menus.
I guess you know something I don't then.
Edit: Just tried it again. I never realized that, but that's probably cause I usually open the movies from files and not the program.
Which file do you double click to make VLC auto open the movie?
oh ok ok. Idealy I wish there was a way to have a folder containing lots of single files (as opposed to folders with movie VOBs in them) that would represent each movie so If I double clicked a movie it would auto play.
That's why I suggested avs dvd player. you can double click teh video_ts ifo file and it will auto play the dvd.
Does it play menus and all as well? And would all of the video info need to be in the same folder, or could I use a shortcut to the video_ts file and rename it the name of the movie?
